Briggs Twin Cylinder L-Head
Has to be the pump. Something not installed right in the pump. Time to get the manual out and check the assembly.
unclelar
have purchased 2 pumps and installed new diaphragm and gaskets as manual shows. Finally purchased on of the round plastic pumps that are used on B&S engines and I think that it is going to work. Will know more tomorrow.
unclelar
got this engine running. the round fuel pump worked. took the old fuel pump off and just used the cover to close up the front so gas would pump into carb. j-b welded the vent holes closed in the cover. runs good now.:smile:
Congratulations, been there and done that, I know it feels good after all the time and effort you put in.
