Briggs twin cylinder cam timing
tim4
I am timing a briggs 446777 twin cylinder engine and the crank gear has a dimple on it but the cam gear has a line and a dot. Which mark do I use for cam to crank timing thanks.
I tried to send you a reply and a Service Manual but it bounced due to bad address?? I have sent another one. I no longer have a 44 series cam to examine but I think dot to dot.
Walt Conner
