Briggs & Stratton XR 13.5 HP engine Carb jet
TPS12
Where can I get a high-altitude main jet for the carburetor? Need 6000 to 8000 FT.
Will need to get the actual model type and code from the engine to look up what is available for your engine. Could be located on the metal shield around the cylinder, stamped into the valve cover. or some of the newer engines have it stamped into the side of the block, with some located next to the drain plug and the bottom of the engine.
Look up your engine number then the carb. HA jets should be in there. Many places online have parts lists for free.
