The push rods are the same length but the exhaust is steel to compensate for the heat. The one that broke is most likely the aluminum intake rod. and it probably wore out where it rides against the valve guide. If so, use an exhaust rod in place of the aluminum one. This is an approved practice according to our Briggs DSM.
