marcpilot1
- Sep 17, 2016
- 2
- 7
Hi. I found a lawn mower last week and got it running yesterday, finally! It says on the sticker, on the front of the mower, that it's a- "Yard Machines by MTD". It has just a little Briggs and Stratton engine. Also the sticker says "22" cut, 500 series, 158cc/5.00 ft-lbs gross torque per SAE J1940, and on the side it says, "Side Discharge / Mulch, PUSH MOWER". Whatever that means?
One sticker on the gas tank says "Engine Family: 9BSXS.1581VG", then, after that, it has some other engine family numbers, and those are: 278636
Theres some other numbers for- "EU:", Some for "Displacement:" and some for, "EPA Compliance Period", CAT: C.
Oh! And theres a model # as well, I forgot to put that down for you. It's model# 11A-504E000 and serial# 1A040K21944.
I found out it's discontinued too, I think. It said somewhere it was a 2000 model. Anyway, with all that info(I doubt any of you all needed it all! ),but I was hoping you could figure out which push mower and engine this particular mower is. Then I was hoping that someone might possibly be able to help me with HOW to change the oil in it.
I just didn't want to leave any info out that might have prevented anyone from knowing which mower this was. But if it was TMI, sorry bout that! Just let me know what most people only actually needed.
Thanks for any info! And because of where I found it, I know it had sat up for a long time, so do you think I need to change the oil/filter a little differently this 1st change? If anybody needs any more info about this mower, just tell me. No problem. I do have a couple pics if you think you want those. And Thanks again!!!
