TylerFrankel1
- Feb 7, 2020
- 16
- 124
Hey everyone! Got questions about my old opposed twin Briggs again. Long story short, I work at a shop, last year someone dropped off a half-disassembled opposed for scrap. I took it home, tore it all the way apart, cleaned up insides, honed, re-ringed, re-sealed, checked valve clearances (were miraculously all good), inspected rod/crank by eye and saw no wear scars, reassembled. Didn't plasti guage crank unforunately. But test fitting rod to crank was tight, didn't feel slop. Anyway, I finished my minor rebuild and installed it on my Troy Tractor. Got it running pretty nice. Did a break in oil change after 5 hours. Currently running super tech SAE30 oil. Probably cut ~20 yards with it for like 1 hour each time average since the build. So I'd guess 20-25 hours running. After sorting out some troubles with the ancient carburetor it's been doing just fine.
However, at work the other day, a mower with an opposed twin came in (they're getting more rare as they age). I fired it up to move it and noticed it was a lot quieter than mine. Wrote it off as a fluke. Another one happened to come in. It also is a lot quieter. Not exhaust, but the engine noise itself. I brought mine in to work, had the boss listen. He thinks bottom end/rod knock. Not what I wanted to hear. But it's always sounded this way since I built it, I didn't think anything of it because I didn't have anything to compare to at the time. Just assumed they were loud engines. It hasn't gotten worse or anything in the 25 or so hours its been running. I got curious so I searched around youtube for videos of these engines running. Most of the ones I heard running on youtube had the same characteristic knock-like noise. The two at work almost seem like outliers being so quiet. Is there a known phenomenon with these "twin-II" engines where they end up sounding knocky/clacky? I read somewhere something about timing gear key getting worn could be a cause but I didn't explicitly notice that when I was building the engine. I have videos of my engine running, the two engines from my work running, and various clips from around youtube for reference below. Just looking for anyone with thoughts, advice, opinions, etc. Thanks!
My Opposed Twin:
Opposed Twin from Work #1:
Opposed Twin from Work #2:
Opposed Twin from Youtube #1 (Sounds Knocky):
Opposed Twin from Youtube #2 (This Guy Has The Same Question):
Opposed Twin from Youtube #3: (This Definitely Sounds Like Rod Knock, Has Different "Snappier" Sound, Makes Me Think My Sound is Something Else):
Opposed Twin from Youtube #4: (Again, Definitely Rod Knock, And Sounds Different from My "Knock"):
Opposed Twin from Youtube #5: (Sounds Knocky):
Opposted Twin from Youtube #6: (Sounds Knocky):
Opposed Twin from Youtube #7: (Sounds Knocky):
Opposed Twin from Youtube #8: (Sounds Especially Knocky):
Opposed Twin from Youtube #9: (Sounds Knocky):
Opposed Twin from Youtube #10: (Sounds Knocky):
Opposed Twin from Youtube #10: (Less Knocky):
(Yes I know I'm crazy for finding and posting this many videos. Trying to provide evidence for my claim, that most sound like mine from youtube, LOL).
My Opposed Twin:
