Have a push mower with a Briggs & Stratton 500E series engine.
Wife mowed part of the yard the other day but ran out of daylight, I was going to finish yesterday...I went to pull the string, and it would not budge. Wife walks by and says "yeah it was hard to start yesterday too" Thanks
Anyway.. I look under the mower and there's a bunch of moss and junk wrapped around the shaft. I cut it all out of there, and after a few tries, I can spin the blade by hand. hooked the spark plug back up and tried to crank it but it will not turn over. String pulls ok, flywheel turns but it won't crank.
I replaced the spark plug, and verified that I do get a spark when I pull the cord.
Took fuel tank off, checked the path from tank to carb, all ok.
Verified that the primer bulb sprays gas into the carb.
tried pouring a small amount of gas into the spark plug hole then putting plug and wire back, Still doesn't start.'
Checked the flywheel keyway. key is there and intact.
I am obviously not a mower repair expert but am somewhat mechanically inclined..and also stumped.
One thing I'm not sure if may be an issue...there's a pull rod that appears to be govern the carb. pulling it back closes a butterfly valve in the carb...but I can't tell what's supposed to actuate that rod normally. maybe something came loose (?) or would that cause a no start condition? Any help welcomed...thanks
