briggs stratton model 135292 issue
troybilt pony
hello there,
this is not a lawn mower issue but i think the engines may be the same.. hopefully someone can help me.. i bought a old troybilt pony rototiller.. the guy who sold it to me said he broke the white piece that holds the choke/run in place. he could only get it to start by pouring motor through the air filter hole. don't know what i got myself into here..
troybilt model # 135292
type 015801
motoman
I own a later model (super bronco) with the tecumseh single slanted cyl. It is very picky about choking and easy to flood, but a good engine and very easy on gas. Anyway the choke is a two position. This summer it wants one turn over full choke , then choke off or it floods. Removing the air cleaner starts the flooded engine immediately. This may not help you directly but in long run. I noticed there are manuals free on line. The air cleaner is marginal and will let in dirt unless you fuss with it.
troybilt pony
hello,
here is a photo of what i'm dealing with.. i took apart the top of it.. air filter is really really dirty. heres the thing that the previous owner snapped. he could only get it started in really fast and by pouring gas direction in air filter area.
is this fixable or am i screwed?
Fish
Yeah, you likely just need to go through the carb properly. It looks like someone has tried to remove the muffler, so check and make sure that they did not break any bolts or strip out any threads....
troybilt pony
i'll do that
troybilt pony
does anybody know which way the spring goes? it fell out before i could see which way it was assembled.IMG_3526.jpgIMG_3527.jpg
Fish
the spring first, then the rim over it, then the diaphragm.
Fish
To change out the choke rod, just pull straight up/out on the choke flap with a pair of pliers, the choke rod comes right out and the new one will slip right in.
