Yeah I looked their earlier. The person that took it apart remembered how the governor spring hooked in and where the two long linkages connected. He just didn't know how the two short linkages hooked in from choke and throttle to the throttle control assembly. I figured them out when he gave me them though. Got all of them right, had a problem getting the carb(pulsajet) primed up but finally got it and it's now running great. Engine is on a pull behind tiller using an atv or lawnmower, tiller #'s come back as Simplicity but haven't seen anything that looks exactly like it. It has a boat trim motor that raises or lowers the wheels with hydraulics.
