I have a BOLENS MTD model 11A-414A065 push mower with a BRIGGS & STRATTON 158cc 550 series engine on top. I had completed cutting the front yard and had just started the back yard. The grass was excessively high as rain had kept me from cutting for just over a week. Since the grass was so high I was using a grass catcher vice attempting to mulch the grass. I was pushing over level ground when the engine stopped.
After letting the engine set for a brief period of time I was able to get it started for upwards of one minute, but then it died again. I had white smoke coming out of the muffler so I changed the oil, but no change in symptoms. I've been through the mower's and engine's manufacturers web sites for technical assistance with no definitive guidance. I've been through the owner's operating manual with no definitive guidance. Actions taken to this point since this problem arose are:
If anyone has experienced this situation I would greatly appreciate how you fixed it.
- Verified gas tank is full of fresh gas
- Ensured gas tank is clean
- Verified air vents in gas tank cap are clear
- Cleaned foam air filter
- Verified primer works
- Verified carburetor is clean
- Changed the oil in accordance with the operator's manual
- Carburetor hasn't been adjusted
- Spark plug contact is free of corrosion and has a firm connection
