Briggs & Stratton engine replacement
Adam195707
Hi, I have a blown Briggs & Stratton 8hp 195707 0112-01 in a Murray ride on lawnmower, can I replace this with a 195707 0421-E1 engine? Not sure if the shaft is exactly the same length although it has two similar looking pulley wheels (in a photo)
Well it depends on the date codes as two different crankshaft were used depending on the date code
The potential replace PTO end of the crankshaft is only a tad shorter (.100 of an inch shorter). Old crank PTO is 3.156 vs the new crank 3.056
As you would think none of the internals are same. But than that they should exchange fine other some difference in the wiring which is easily figured out.
Adam195707
Hi Startech, I bought the engine and fitted it with a few minor changes required. Starter was making nasty clicking sound and wouldn’t start the engine. I checked the battery which is producing 13 Volts and just under 1amp. Then took starter apart to find broken magnetic bits from casing so new one on order. Will try again tomorrow
Adam195707
Still nasty clicking sound
