It's not the blade. I recently sharpened and retorqued the blade to the recommended 60 ft. lbs.As stated, rod knocks don’t come and go. Have you checked the blade for looseness? I would remove the blade and clean everything up good. Reinstall the blade, making sure it is tight and test run. Also, make sure that all engine to deck mounting bolts are tight.
