In theory the aluminium should expand at the same rate as the engine so the valve lash does not change as the engine gets hot.
In reality I swap them all with steel ones when they start to wear then set the vales slightly tight.
If the engine was doing 10,000 rpm then the weight and inertia of the push rods need to be considered but at < 4000 rpm not worth worrying about.
