Briggs & Stratton Coil fails when hot
originalswampfox
Has anyone had problems with the B&S coils failing when hot?
reddragon
yes...my neighbors 2003 lt1000 17hp briggs...it would heat up and kill the engine...let it cool down and spark came back...it drove me nuts:confused2:
originalswampfox
Thanks reddragon that seems to be my problem. After i cut for 30-45 min I shut it off to re-fuel and rest for a drink, Will not start until it cools down. I've cleaned the carb, change the spark plug and checked the spark(cold). If i take the plug out(hot) I can spin it fast enough to get a spark but I'm an old man with one lung and don't think I can spin it fast enough hot. Maybe it's time to start repairing the electric start also.
reddragon
im curious...what is the mower? and engine hp?
originalswampfox
Craftsman 6.5 hp quantum walk behind. If you have any other ideas let me know. I have a hard time pulling the rope and looking for a spark at the same time especially with the plug in. When I hold the plug in my hand I can feel the difference hot vs cold, but as I described in earlier thread using this method lately I have developed a stutter in my voice.
reddragon
this is a great little shortcut tool....just clamp it to engine ground where you can see it....[best in the dark].....and of course the spark plug pliers....so you dont pull a Ben Franklin:laughing:.....vapor lock comes to mind ....but that wouldnt come out of nowhere ........except...once i worked on a mower that caked grass filled in the cooling fins ..driving the temp. way up...and that cooked all the carb gaskets....keep in touch:wink:
originalswampfox
The old man just broke down and bought a spark tester. It looks just like the one in reddragon's picture. I tested my coil cold plenty of spark, cut grass until time to refuel the grass was wet so the engine was plenty hot. Filled it up checked the spark, it had good spark but wouldn't you know it, it cranked first pull. I'll have to wait and try it again later. I'll let you know.
reddragon
isnt that just how it goes?!:confused2:
whiteshu
The 6.5 hp B&S Vanguard on my tiller has no spark. I have tried two replacement coils. A small engine service technician told me that I probably ruined the hall effect switch. I don't see how that is likely. I have tried leaving the kill switch wire open. No spark, hot or cold.
Whiteshu, please post the model, type and code numbers for your engine. With them we can tell whether you have the correct coil. Second, post the part number of the replacement coils and where you purchased them. If both were purchased on Fleabay or AmoScam, the is a definite possibility that they were bad before you installed them. 90% of the techs on this forum never go there, except in an emergency.
