EngineMan
- Jun 12, 2012
- 2,275
The diaphragm(s)
Best thing you can do, if you are saying that there is no fuel solenoid (part No 947A) is to work your way from part 434A to 394B taking your time ie take one part off at a time, look at the pic and making sure that they are fitted the right way round, (all parts) and make sure there are no hole's in the diaphragm(s) even if it is just a pin hole...! that is your fuel feed side and may well be where the problem lay...! good luck. keep at it, am sure you can fix it.
