Briggs & Stratton 699951 Oil Sensor Module
hotrod351
how do you test this module. any one.
hotrod351
any one know what ohms this should be, if any. the low oil sensor connects to it and it seems to be bad. if i disconnect the low oil sensor at the crankcase i get no spark but if i disconnect the module form the kill switch i get spark.
motoman
hotrod, what is it supposed to do? It looks like a two wire make/break. If easy for you pry open lift one side of the can to look at the internals and report.
