Briggs & Stratton 300e hardly running rough
jay07
Got given this mower, originally it ran but was surging and thought a simple carb clean would sort it. Cleaned the carb, now it’s barely running! Replaced fuel, filter, plug etc. getting ready to throw it off a cliff.
Bertrrr
Clean it again and check all the fuel supply side lines , filter ,screens , vent on tank etc.
jay07
I’ve had the carb off and cleaned it about 4 times, I’m now thinking possibly governor problem? No choke on this mower just a primer.
Bertrrr
Governor only regulates the speed , it has to be running well enough for the governor to respond , if it will not run smoothly there is still a carburator / fuel problem I usually find some small debris or rust particle in the main jet when they run like this
