charentejohn
- Mar 8, 2014
- 3
- 10
Hi, first post here as I am stuck on what to do next.
I am actually in France but an engine is an engine......
I have had the mower for 4 years, small MTD ride on, and it always works well with no problems.
Just started it for the new season (grass growing as we speak) and it ticks over fine but stumbles and cuts out when the revs are increased.
Some smoking when first run but none now, no backfiring as such (only a small one through the carb when it stalls).
Seems to run for a second on max speed setting then hesitates and stumbles, return to slow before it cuts out and all ok, leave it on high and it stops.
What I have checked.
Fuel supply ok, timing ok (cleaned and reset the timing 'block'), checked plug and cleaned it, fuel is 6 months old but should be ok as stored in a sealed large container.
Carb was replaced a year ago.
Can't think what to check/adjust next. First thought was restricted fuel but seems ok ?
I found some info on the net but most start with the worst case, engine exploded internally, so I was hoping for a few better options. It was running fine when last used in September last year.
Any help appreciated, John
