Briggs starter issues grind and locking
Briggs Intek 31P7770348 E1 04052QZA. Picked up a nice mower For 300 a couple years ago. Now I have a starter issue. The starter wouldn't always catch and just grind. then It wouldn't even engage. Checked it out and found the bendix was totally destroyed. Went to the grave yard and got a good starter and all worked good for a day. What I found is It either grids or locks at one spot on the fly wheel. The fly wheel is part #591760. I think the teeth are worn on the fly wheel. It always happens at the same spot on the fly wheel. The teeth either don't mesh and grind or the teeth lock up edge to edge. The picture here is showing the gears in a locked situation. I have 2 junk engines.
3197770377E1 with a flywheel part number 591758 And 31f7070112E1 with fly wheel 693556 My flywheel is 591760. Can I use one of the two flywheels to replace my 591760? Please advise. Thanks , Matt.
Im not sure of the situation but the starter gear on my old Harley would behave the same as you describe. Im believing the issue was a worn bushing that the starter gear shaft spinned in - causing slop and bind. Was my situation.
congrats on getting it running. Keep an eye on the mesh and make sure no further damage occurs.
