I have a craftsman edger with a Briggs 500 series engine. Model #10t502.
It has the plastic pulsa prime carbs on it. The engine fires without problem, runs fine for a few minutes and then starts to act up. It sounds like it’s missing and you can smell it’s running rich. It will do this intermittently... runs fine for 10 seconds, sputters, runs fine for 15 seconds, sputters... and so on.
Here’s i what I have done:
Carb clean with diaphragm and gasket replacement
New spark plug( previous plug had carbon built up)
New airfilter(oiled foam)
Gapped the coil... the previous owner actually had the coil touching the flywheel and I fixed this when I regapped the coil. There is some scoring on the fly wheel from this.
With all that nothing has improved. Because I could smell it running rich I took the air cleaner off and the sputter went away and the engine runs steady, it also doesn’t have that rich smell. As soon as I put the air cleaner on sputtering comes back. These are oiled foam elements and I thought maybe it was over oiled so I put a brand new non oiled filter in and tried running it with the same sputtering as an outcome. I then oiled the filter as usual.
I also pulled the kill wire off and that didn’t help. The only thing that makes it run correct is to take the air cleaner off.
Not really sure where to go from here. Maybe the coil was damaged from when it was rubbing the flywheel but why would taking the air filter off make the engine run correctly.
