jepperlein
I have a older little wonder blower Cat#9005PD serial#8120146, its got the chrome handles. I want to put a new briggs engine on it because the old one has low compression. Its 5hp, the case is a bit rusty, I think the numbers are as follows: Model#130202 Type#0770 01 Code#81052907. I'm pretty sure they all have a 1" diameter shaft, I'm just not sure which engine to go with. Any info would help.
Thanks!
John
Thanks!
John
