The G-Man
- Jun 29, 2016
- 1
- 4
Hello everyone. I have a briggs 4hp Quattro (10A902 2271 E1) that I am trying to repair.
The governor setup had been tampered with and the carb needed a cleaning. I have replaced the governor springs. The carb is now clean and it runs but seems to be a little fast.
It has a lever style throttle control. When the lever is in the "slow" position it runs around 2500-2600rpm and at full throttle it runs around 3330rpm. I thought it should run around 3200rpm at full throttle. (Rpm readings were done with a tiny tach).
![image-1776351479.jpg image-1776351479.jpg](https://www.lawnmowerforum.com/data/attachments/18/18298-23f16fbf7dd77b7c318920924a98d6df.jpg)
Any advice on what rpm readings should be at low and full throttle? How would I go about adjusting the max rpm?
