Hammermechanicman
- Jan 10, 2020
- 69
- 3,888
That kinda what i thought
I need a tank assy for briggs 5hp on an old 2400watt generator right now to replace a rusty one. You got a link to that 25 dollar tank? Tks
Wait............does it really???check them for being clear by blowing into the tubes. This proves effective, although its probably shortening my lifespan and makes my mouth sore.
If it is rust you may be fighting a losing battle. You can remove the tank and put a big handful of machine nuts in it and shake it for a few minutes or put it in a vibratory cleaner to shake it then rinse it out a half dozen times and hope you get the loose rust out.Thanks everyone! I've determined that the issue is with the pickup tube finding every tiny piece of dirt in the tank. It keeps clogging. Hopefully at some point it will get the last of the dirt and stop clogging. The pump and everything else is working quite well. Starts on 2 pulls.
so even just a little bit of gas touching your lips will hurt you.........?Well Logert it does only if you not drink gasoline regularly. Most of us don't as it is hazardous.
