Tenneesseez
- Jan 22, 2012
- 1
- 1
Good Morning!
New Member, Have a Technical Question pleze.
Have a Murray 48" cut Riding Mower, Model Tag faded so bad can not make it out says "Wide Body" on mower think maybe 1995-1999 perhaps, its powered by a 18 1/2 HP Briggs 2 cyl. 4 stroke Industrial engine.
Was mowing last fall, ran out of gas, bought gas ,filled it up would spin over but not start, finally checked the plugs
no spark at either plug!! Found a fuse ,pulled it would not spin over, reinstalled fuse would spin over ,still no spark. Am at a loss as to why running out of gas would cause this problem. Since mower spins over fine, is there a possible Woodruff key that could have stripped when the mower died under load and would allow it to spin over but not fire?
Help anyone? Thanks Tennesseez
