Briggs Pre-Filter
lefty2cox
Briggs: 407777-3195-G5
I just got a new air filter for this engine and it came with a pre-filter. The original did not have one. Do I use it or will it screw with the mixture?
Thanks.
cpurvis
I'd use it. I have two mowers with pre-filters (foam wrappers) and they do a pretty good job of catching big stuff. Don't forget to clean it every now and then (or per manufacturer's recommendation).
It won't mess with the mixture; they're pretty coarse and non-restrictive.
7394
Neighbor has a 23 hp Briggs that has the green pre-filter on it stock. But he doesn't do much cleaning on it.
7394
Cpurvis- I think they should come that way with the 2 stage filter set-up.
Best mod I did on mine to date.
Ranamow
Thanks.
Not all new filters come with pre-filters. Definitely use it!
mechanic mark
Absolutely, I wash pre-filter with a small amount of dishwashing liquid & water hose, rinse thoroughly & squeeze dry. I inspect cartridge filter by holding up to sunlight looking from inside of filter outward after tapping filter against a solid surface to remove dirt etc.
