I am a little stumped on what the issue or fix but I have a Briggs Platinum (120000 series) engine on a Craftsman lawnmower (2013 model). This engine has the auto choke and primer. It has been acting up last year and this year too. It used to start with one pull and now on cold start most of the time it will work within 3 pulls. On a hot start I struggle with getting it going until the engine cools.
Engine Detail:
Things I have tried:
I am a little confused what is causing the problem and what needs fixing.
Engine Detail:
- Model: 128M02
- Type: 0962
- Code: F1
- Auto choke Thermostat replace: It was a little sticky at the end of last year so I thought that was the main culprit for the hot engine issue but problem still exist
- Spark plug has been replaced with Champion RJ19HX. I am getting spark with the spark plug checker.
- Air filter has been replaced
- Carburetor bowl and main jet (bolt holding the bowl) has been cleaned (without removing the whole carb) and spray as much around the choke
- Resistive check the ignition coil, measurement seems normal. Also re-gapped the coil to the flywheel.
- If I get a rod or something to manually close the choke when the engine is hot, I am able to start the engine and remove the rod immediately right after the engine seems to start up.
