Briggs - oil into valve cover from push rod guide
JES2
Location
Southwest Georgia
I have a Briggs and Stratton 205cc, Model # 1222032 0536 B8. It had been sitting up a while. I've got it running, but it's leaking oil into the valve cover at the push rod guides. There is enough oil coming out that it leaks into the breather via the breather tub. It's a pretty significant amount of oil coming out. I put some spray in the spark plug hole and let it soak for a while, pulled the crank a few times to hopefully loosen up the rings if they were stuck etc. when I first got it running.
Any ideas?
