Briggs M288707 12.5 HP Intake/Carb Bolts???
seagiant
Hi,
Looking to put together this Engine I was given but missing a few things.
Having trouble inding these bolts from usual sources, do not even see them on Schematics???
Where do you get missing Engine Bolts???
Carb to Intake stud screws are PN 690227. Specialized.
Nuts for the studs are PN 690958. Flange style.
Intake to the cylinder screws are PN 690953. Common screws. The only difference is that these have a torx screw head along the hex head.
As for the screws (bolts) they are listed on the IPL for the engines but you will need the type number along with the model number.
Here is an example from the 288707-1104-E1 IPL.
seagiant
Hi,
Thank you VERY VERY much!!!
