New to posting but frequent reader.
I have an issue that I need some test suggestions for.
Briggs Stratton 282707 12HP in an older weedeater rider.
Picked up a mower from a friend that was upgrading. Normal maintenance plus new battery, solenoid, and starter(rusted out base and stripped teeth on top). Also got a new key switch that is a 5 pole as the key was broken off in the old one.
It appears the seat safety is has been taken out of the loop by simple connecting the two wires.
The cutting deck engagement safety sensor was disconnected when I got it. If connected will always kill the engine on cutting deck engagement. Deck works as expected if the wiring harness to cutting deck safety switch is disconnected.
Engine will start without issue if the solenoid is jumped, but only if the key is in the OFF position. If the engine is running and I turn the key to the ON position the engine will die.
Could anyone suggest some testing for me to work through, in order to isolate the issue. I am at a loss on where to start.
Also, does the cutting deck safety switch do more than I think it does?
Thanks for any guidance.
