Hi all,
I just picked up a mower with a 18HP Intek 1 cyl. I bought it not running, and I'm trying to fix that. The carb was bad so I replaced that today. The mower will fire up and keep running, but it consistently backfires through the carb. Not just every now and then, but it seems to be every other fire of the motor. It seems like (may not actually be the case) the exhaust alternates between the exhaust pipe and the carb. I replaced the spark plug and verified the gap on it. The engine obviously has very little power in this condition. Does anyone have any ideas? Is it possible for the ignition to only fire every other time? Thanks in advance.
Brent
Brent
