Briggs intel engine problem
groundsman1
Please don’t reuse the head gaskets. They are designed as a one use only and you’ll be headed for more trouble if you try to reuse them.
Hi
sorry i meant to say I will replace it and give it a try?
groundsman1
Hi all
thanks to a very good youtube video I have found the fault. The main jet had fallen out so there was no control on the mixture. Luckily I have found the jet with its o ring but its loose in the hole, so ether the o ring or the jet body is worn.
