Briggs IC problem
bwestbrook
Compression jumps up to about 115 psi if I put a little oil in the cylinder.
bwestbrook
Intake valve
EngineMan
From what I can see from the photo, inlet (intake) valve is not seating right, if you have a valve grinding set I would redo the valve(s) if the intake valve is not closed on compression it will blow fuel out of the carb.
bwestbrook
Yeah I took the head off a put spark plug back in and poured gas over the valves and it does leak which told me they weren't sealing properly.
EngineMan
Redo the valves and then engine should work much better after that, just take you're time in doing them, it will be worth it..!.:thumbsup:
