In May of 2011 I purchased an Ariens Zoom 52inch ZTM with the Briggs 24HP motor on it. This weekend as I was mowing my mower started to back fire and loose power. I had the mower transported over to the dealer that I purchased it from to try and figure out what was wrong with it. The service department called and said that one of the pistons had seized and that I needed a new head unit. The service department then informed me that my warranty had expired about 60 days earlier and that I was basically S.O.L. I was then told that the parts would run me around $200.00 - $230.00 plus 4 hours of labor at $66.00/hr. I have changed the oil on my mower 4 times since I purchased it and I only have 90 hours on the mower. I called two local Briggs dealerships in my area and asked if they had seen any similar problems like mine. Both service managers stated that they have had several issues with Briggs engines just like mine. They went on to explain that for some reason the chamber gets too hot causing the piston to "stick" causing the engine to fail. I was wondering if anybody has had any similar issues with this engine? I take good care of my mower and feel that this is maybe a defect with the engine. Any suggestions (helpful that is) on how to deal with this problem would be appreciated.
Thank You
Thank You
