- Feb 19, 2020
- Threads
- 119
- 12,787
Probably trying to use a smart phone. People sometimes needs a real desktop computer with a large screen.
Rust is not your friend; it is a sneaky enemy.
These carburetors are mounted on steel tanks that tends to rust a lot. This rust can even clog up unseen passage especially in the tower section. Over the years before the tanks became unavailable I had drill the tower steel plugging ball(s) and clean the passage contain within. Once cleaned out that passage has to be resealed. Even ultrasonics won't clean out the rust nor will dip cleaners.
On that many of these carburetor's towers never had a filter screen install. Most were installed by tech upon the first major repair. An after thought on Briggs part.
Also check the valve clearances as this is a very old L-head engine and the valve clearance probably at zero.
I do have one 3 qt tank left that I am saving for later use. That is if the customer will to part with $150. When they hit over $100 the customer quit buying them and I don't blame them.
