Smokeeater
- Jun 12, 2018
- 59
I'm replacing the cam shaft in a briggs engine (31R607 0011 G1) cause the compression release broke. Everything else moves around ok so I think I got lucky andit just dropped in bottom.
Here's a pic of all the pieces I found in bottom. But there was a white plastic piece that I wasn't expecting. Is there a plastic piece somehwere between the arm and the camshaft itself (see pic)
