GetTechnicalWithJd
- Jul 28, 2013
- 128
You will need to connect to a wire that is hot when the key is on and in the crank position, and not hot when the key is off, or you could just dis-able the solenoid.
This is typically labelled 'L' on the ignition switch. Sometimes this is on the spade terminal itself.
Problem is if your old engine did not have a carb solenoid your key switch may not have this function. Check it out and let us know.
