19maiden85
- Jul 3, 2015
- 2
hi there please help a scottish guy in need!!!!!
i have a problem with this mower, the battery seems fine and when you turn the key a yellow light on the "dash" lights up and nothing happens. I have tested the switch on the seat, where the bag at the back gets put on , the ignition switch, the blade height switch, every switch i can see and nothing!!!! i have jumped the starter and it tries to start the motor . so to me the motor is ok but the electrics are the problem please help me if you can cheers!!
i have also checked the solenoid and seems to be working!
