turbozeke418
I have an early 2000's Craftsman LT3000. 2 years ago the engine blew and I had a friend who had a 90's LT2000 which was the same tractor with hydrostatic trans just less HP. I believe the engine is either a 16.5 or 18.5 HP. It was a direct replacement without any issue. My issue now is that my starter grinded down the starter ring. I pulled the flywheel off and now looking for a replacement. Are they pretty much interchangeable? These are the dimensions of what I need to replace.
5 1/4" from magnet to magnet (inner distance)
8 1/4 (outermost distance outside of starter ring)
Each magnet is 3/4" x 1/2" and there are 12.
From the top of the spindle to the bottom of the inner part of the flywheel is 1.5" and the entire unit is 3.5" top to bottom.
I'm sorry I can't give you a model # of the engine. I can't find #'s anywhere. Anything help you can give me would be appreciated. Or maybe if someone has one laying around for sale that will fit?
