Hello all,
I recently bought a cub cadet zero turn that has a briggs and stratton model 407577 22 hp motor on it. When purchased I had jump the solenoid to get it running (key does nothing), however it would run wide open throttle.
I have done the following:
Changed both spark plugs
Changed oil
Changed solenoid
Changed air filter
Changed gas filter
Put new gas in it
Replaced carburetor with brand new one.
I still have to jump the solenoid to turn over the motor. However after making those changes, the mower will not stay running. It will run on starting fluid for 1-2 seconds then quit. The same thing will happen if I put gas directly into the intake/carburetor. When pulling off the gas line that hooks into the carburetor, there is always gas that comes out. So I would assume there is gas able to get into the carburetor.
All help is greatly appreciated!
Changed oil
Changed solenoid
Changed air filter
Changed gas filter
Put new gas in it
