Engine began surging after 45 min of use. fuel cap cleaned and free of debris.
Changed plugs. still ran rough after
45 mins or so. all gapped properly
Wouldn't charge battery so stator replaced. flywheel batteries damaged so it was replaced.
ran okay again but began running rough after 45 mins.
Ignition coils replaced. carburetor cleaner sprayed into intake in effort to
clean. engine ran until fluid dissipated. now cranks but won't catch
flywheel out of alignment?
fuel pump does put out fuel, but how much is enough?
could it be carburetor, needle what do you think?
