Cajun power
- Apr 11, 2023
- 86
if it starts and runs and there is no other performance problems other than just a hard pull start...then it's probably going to be either and overfilled oil...or there is some trash wrapped around the mower blades/spindle. I am assuming there is no blade engagement switch (like a PTO) on this push mower yes. so when you are starting it, you are also cranking the blades over. I would look there...it's probably why the blade got loosened....just an idea.
so two things: check the oil fill. make sure it's not overtopped. Then engine off, check to see if there isn't some trash wrapped around the blade and shaft.
noting: when tilting an engine to one side to get under the deck, make sure you let it sit for about 15-30 minutes before you start it. Allows time for the oil to drain back out of areas where it can cause starting problems and performance issues and foul plugs as a result. fuel can also end up in places like the air filter and out of the fuel cap, potentially causing fire hazards...I think there is a specific side of the mower to tilt when doing an oil change for most push mowers. Check that out in the manual. It will help reduce the chance of problems.
