I have a mower with the above engine in it 2018 vintage, my problem is I can find numerous stamps and stickers on the engine but nothing that seems to relate to the model etc numbers.
stamped on the exhaust is 595506. And on a sticker on the flywheel cover 17 0908 56 8126.
my problem is when I bought this mower 3 weeks ago and I test drove it first it worked as it should, but the seller said he altered the valve clearance to make it start better. Result is it did not enable better starting so I rest them as per web find and it started better, but it was hunting and the throttle lever made no difference so I thought fuel starvation.
so I have stripped carb and checked jets and others bits, when I installed it I noticed that when the throttle was moved nothing happened to the carb levers, so what’s missing I believe there should be a third spring from the throttle lever to the plastic moving parts
so,I need to see a parts diagram which is why I need the model/type numbers
