markcopple
- Mar 28, 2020
- 1
- 5
I have an old Briggs and stratton 3hp 175cc motor (early 80s) engine 80202-1647-01. I need new piston rings (all three). I downloaded the part list and it gives several options and I do not know what to order. I am given five options on the part list:
294224 SET, Ring -(.010 Oversize)
294225 SET, Ring -(.020 Oversize)
294226 SET, Ring-(.030 Oversize)
294232 SET, Ring -(Standard)
297201 SET, Ring -(Standard)
This engine has never been serviced *EVER* and I have never taken an engine apart before. So which one(s) do I need? I assume that "SET" means that when I order one of the above I get three rings. what does the oversize mean?
THANK YOU!!!!!!
THANK YOU!!!!!!
