- Sep 24, 2017
- 285
- 6,850
This...Personally, if you have access to both sides, I would use bolts and locknuts.
I use grade 8 material, just a personal preference.
bolt, flat washer, lock washer on the nut side.
Well 3/8" dia probably wouldn't fit so what diameter would you recommend ? Also are the lock nuts the ones with teflon material in the center? Probably what I will do . Also need to figure out the size bolt that screws into the center of the pulley/ pto shaft. Would think a new engine would come with one but it didn't.Personally, if you have access to both sides, I would use bolts and locknuts.
Thanks iam going to go this route.This...
I would take one of the self tapping bolts with you to the hardware store, and compare them.. find one closest to the diameter of the screw, just a bit smaller. and longerWell 3/8" dia probably wouldn't fit so what diameter would you recommend ? Also are the lock nuts the ones with teflon material in the center? Probably what I will do . Also need to figure out the size bolt that screws into the center of the pulley/ pto shaft. Would think a new engine would come with one but it didn't.
| Square PTO Key #1 | 0.25 x 2.688 x 0.145 |
| PTO Keyway #1 (mm) | 6.34 x 68.28 x 3.683 |
| PTO Threads | 0.438-20 UNF |
| PTO Shaft Diameter (in) | 1.000 |
| PTO Shaft Diameter (mm) | 25.4 |
| PTO Shaft Length (in) | 3.157 |
| PTO Shaft Length (mm) | 80.188 |
A hardened steel tap shouldn't break in soft aluminum. Might get a Craftsman tap and die set. Those have been good IMO.Hate to say this but after a few broken taps that had to be cut out with carbide bits I no longer use any oil when tapping aluminum. I have even broken them using Tap Magic tapping oil.
Just use whatever you want as long as you are prepared to cut out a broken tap as tap extractors don't work either once you break one off in aluminum.
Shouldn't break is different than real life as I have broken several Vermont American taps off in aluminum Kohler cylinder heads The last one shattered so it was a lot harder to drill out with the carbide bit. And this just by using the t wrench that comes with the taps. The taps just gall in place and can't be turn one or the other with snapping them. Ever since I started using the alcohol per my machinist which does SpaceX work I haven't had a single tap to jam in aluminum. Matter of fact they cut better threads.A hardened steel tap shouldn't break in soft aluminum. Might get a Craftsman tap and die set. Those have been good IMO.
Wonder where I can order that pto bolt / washer from , I looked online but nothing comes up in the search.straight from Briggs and stratton.
Square PTO Key #1 0.25 x 2.688 x 0.145 PTO Keyway #1 (mm) 6.34 x 68.28 x 3.683 PTO Threads 0.438-20 UNF PTO Shaft Diameter (in) 1.000 PTO Shaft Diameter (mm) 25.4 PTO Shaft Length (in) 3.157 PTO Shaft Length (mm) 80.188
Crank threads are a .438-20 UNF.
although it's confusing why they have the first number in thousandths of an inch... not a fraction...
You need a 7/16-20 bolt... any hardware store should have them....That is converted to SAE 7/16-20.
