Fish
- Aug 2, 2013
- 5,145
You need to pull the keyswitch first and check the posts, on the backside they have stamped the letters indicating what they go to. If you are getting any continuance between "B" and "M' or "G", then your switch is bad. They can be real squirrelly when they start going bad, as those little springs and balls will wiggle around in the switch and short out different contacts each time.
But of course, molten or chewed up wiring is another thing to look for...
