Briggs and Stratton 17 hp OHV Intec Won't Crank
chetsdodge
My engine will not crank. I can here it click at the fuel solenoid and I do have a good battery. I am sure that it is something simple, but not sure what steps to take next. I did try a screwdriver and touched both screws on the starter solenoid. Nothing! So, I don't think it's that solenoid. Any ideas? I have been looking on youtube, but have not found anything helpful.
Before you start, pull the spark plug & try to rotate the engine by hand.
No use checking the electrics if you have a hydraulic lock, seized engine or jambed belt overloading the stater motor.
Assuming the engine turns freely.
I like to start from the starter motor and go backwards .
Do the following 5 tests, regardless of the results from an or all of them as there can be more than one problem and you want to isolate where the problem lies.
Elimination of individual parts is important so you know by the end, the battery, solenoid & heavy power circuits are all in good order.
1) try to jump the starter motor directly from your car or truck.
Starter turns = starter good
2) do the same directly from the mowers battery
Starter turns = mower battery good
No turn = duff battery, recharge it & try again.
3) check for voltage ( + 12V ) at the solenoid trigger wire with the key in start position
3a) same with ground trigger wire ( 4 wire solenoid ) or body of solenoid ( 3 wire solenoid)
( I like to test V from the battery hot terminal to ground terminal rather than ohms as they give funny readings )
4) leave ground jumper in place ( from step 2 ) & try key start.
Starter turns = power connection good but ground connection suspect ( most common )
Confirm it by trying again, extra ground removed
I run a secondary grouBefore you start, pull the spark plug & try to rotate the engine by hand.
I run a secondary ground from the grounding bolt to one of the starter mounting bolts & paint over both with liquid electrical tape.
5) Remove the trigger ( thin ) wire / wires from the solenoid.
Ground one & bridge from the hot terminal to the other.
Starter cranks = solenoid good.
Solenoid is not polarity sensitive, BUT THE WIRING IS so make sure you remove the thin control wires.
Note a thinner wire on the hot terminal is not a control wire. It is the main power feed to the mower.
From here on things become very mower dependant as starting circuits are getting changed all the time.
Basically the power goes in a loop from the hot side of the solenoid ( saves wire, no other reason ) through the fuse to the B terminal on the key switch then to the PTO switch then to the parking brake switch then to the solenoid trigger switch , easy peasy after you grow the 3rd arm. Use a test lamp and follow the power.
However a lot of mowers with a 4 pole solenoid, run a secondary ground control circuit to the ground solenoid wire through the lap bars.
Then to stop this interfearing with the normal safety function of the ground kill, it goes to a relay with the ground as the switched connection.
These are a PIA as the + control wire to the relay comes from the power loop above and the ground side of the control comes via the normal cut out functions of the lap bars.
Be very careful because if you have a system like this and accidentally send 12V down the ground loop you can fry the magnetos on some circuits.nd from the grounding bolt to one of the starter mounting bolts & paint over both with liquid electrical tape.
Thanks Bertsmobile. I just saw this. No clue why. Maybe I deleted my notification e-mail on accident. Either way, seems like I started backwards. The starter will not turn when jumped directly. So, I am ordering a new one today. Once installed, I will follow your directions. I am hoping that once replaced my problems will be over. I'll post my findings here once I get my mower back up and running.
By jumping directly tou mean - to the body of the starter & + to the terminal on the side ?
Very rare for starter to go dead open circuit but it does happen,.
Check the teeth on the new one carefully make sure they are the same type & number.
Yes. I tried first by connecting the positive jumper to the bolt/wire on the side and the negative to the body of the mower, then to the body of the engine. I have also taken the starter off and connected to the bolt and body. Absolutely nothing happens. I honestly thought I was doing something wrong so I tried more than once on 2 separate days.
I have already turned the motor by hand so it's not seized up. It spins freely. I have also replaced the plug, oil and magneto. I accidently broke the wire on the magneto when i was checking the old spark plug, so figured since I have owned the mower for about 6 years and I bought it used, it wouldn't hurt to just replace it vs trying to figure out how to fix just the wire. I did use the business card trick for spacing the magneto.
