Hi!
I have a 17.5 hp B&S model number 31C707 that won't start. It turns over fine and I have nice spark at the plug. After cranking for a while, there's a loud backfire through the carb (loud enough that the neighbors mistook it for a gunshot). Here's what I've done so far:
1) Checked the valve clearance. I was able to get it to run (although very poorly) by increasing the clearance a bit. It made it very difficult to crank, though. Obviously not a way to run it long term.
2) Pulled the head and the valves look OK (picture attached). Some carbon buildup, but they seem to close fine.
3) Checked the piston and cylinder lining. Looks fine from what I can see without removing the piston (which is a pain). No scoring or scuffs.
4) Checked the ignition timing. I've heard of engines where the key for the flywheel breaks and knocks the out of alignment. I didn't have the correct wrench to remove the main bolt, so I wasn't able to check the key, but the magnets line up with the ignition coil a few degrees before TDC, which seems reasonable.
5) Checked the operation of the camshaft the best I could without pulling the engine apart. The valves seem to open wide and the action is equal across both intake and exhaust.
I'm now out of ideas? Anything else I can do without pulling the engine apart completely?
