Mdesmond
- Jan 10, 2023
- 7
Interesting- so if the throttle goes to the extreme end (rotating the plate on the back) - that clip on the throttle plate will ground out the spark if the magneto wire is attached to the clip. Is the extreme position intended to be the “wide open” throttle position ( so used to prevent over reving the engine?) or the “off throttle position” which is used to turn the motor off?
