When I first start it and it's cold it doesn't surge its not until its running for 5-10 minutes it starts surging. It's probably only ran for an hour since I got it I would hope nothings cloged already but I suppose it's possible. I also noticed when I took the air filter off that it smelled like gas and there was some moisture under the filter.Does it surge on flat ground sitting or rolling through washboard turf? Surging normally, means dirty carb or fuel delivery issue.
Try loosening the gas cap.When I first start it and it's cold it doesn't surge its not until its running for 5-10 minutes it starts surging. It's probably only ran for an hour since I got it I would hope nothings cloged already but I suppose it's possible. I also noticed when I took the air filter off that it smelled like gas and there was some moisture under the filter.
