Briggs 6.5 Intek Won’t Prime
Geo1951
Is it possible to change the bulb from one with a hole to one without??? Since the latter works by suction might it work to eventually inject gas to the main jet?
SeniorCitizen
QUOTE: Geo1951 - After using the Primer Bulb a pull of the spark plug reveals it is dry.
Any help you could give me would be greatly appreciate.
Quote:Geo1951 - I do have the primer bulb with the hole. So it is an air push system. Unfortunately, that’s all this design does is push air and no fuel ejects thru the main jet to actually prime the engine.
You primed it, so why do you think the plug should be wet after I stated what the tech told me?
